animate 2 problem
I just installed daz studio 4.6. Animate 2 trial appears fine, but the left bottom panel is blank.
If you look at the very bottom left of the Animate2 panel, you should see 'Aniblocks' or similar, with a little triangle beside it. Click on that and you should see a popup window. It seems to have changed recently - See Below:
The triangle is there, but everything else is blank.
