Will non-nvidia laptop graphic card run daz Studio?
Hi there.  I recently got a new laptop, which works well for a lot of other purposes.  It's got an i7 chip and 16 gigs of ram.  However it does not have an Nvidia graphic card, it has a Intel HD 520.  I understand that Iray only works with Nvidia cards, so how will rendering be hampered if I use Daz Studio on this machine?  Any info appreciated thanks.  Below are the specs of the card.
Intel HD 520 Graphics
GPU Type
Integrated graphics
Shaders
24 unified
ROPs / TMUs
8 / 16
Core Clock Speed
300 – 1,000 / 1,050 MHz
Memory Bus Width
128-bit
64-bit
Video Memory Size
Shared main memory, depends on system
Memory Type
DDR3 shared
Video Memory Clock Speed
Depends on system
Production Technology
14-nanometer
3D Mark 11 (Performance Mode) Score
1050
  • FishtalesFishtales Posts: 6,232
    Studio will work fine except Iray will render on the CPU only which will make renders take longer to finish. If you want quicker renders then render in 3Dlight.
  • tradivorotradivoro Posts: 74
    edited December 2018
    Thanks Fishtales.  If speed is the only caveat, I'll stick with the Iray.  The laptop is not my only option, it's just that being a new machine I wanted to see if I can get DazStudio to work in it.  I work with Daz Studio on my pc with an Nvidia card, and the results are great with Iray.  I've tried 3Dlight and although the renders work well for some artistic applications, I like the realism of Iray, which I can then further develop in photoshop, if I want something less real, more painterly.  Thanks again.
    Post edited by tradivoro on
