Headshop OneClick v 11
James_H
in The Commons
Another version of Headshop. Having been bitten somewhat by this over several versions, I hung back for Headshop 11 to see if it worked. Anyone any thoughts on the newest version now in store?
Also watching with (guarded) interest - and how does this vary from the full priced version, it seems to have pretty much the same features and even some of the promos are the same.
Outrider, we found the bug that causes the weird neck wrinkle and it is fixed. Still fine-tuning the math to be perfect. It won't even require to reinstall OneClick or HeadShop, only to exchange a small file in the folder. Maybe a week?
Im wondering if OneClick would suite me versus V11; the manual placement of 'dots' might be useful, but outrider's comments are interesting.
I decided to buy OneClick a couple of days ago after the discount, many because of the features that allow you to use three quarter photos and smiles. Overall I'm disappointed with the product and wouldn't recommend it over Facegen, which I also have. The later gives much better results if you have the right type of photo to start with.
I found OneClick buggy and it has crashed several times, particularly when trying to use the features tab and apply age etc. It also has an annoying habit of deleting body parts when you cancel a face generation which means you have to reload and start again. Of the faces that I have generated the results are underwhelming to say the least. I didn't have any problems installing it or following the limited documentation but was concerned about the number of times that it crashes.
Overall a bit disappointed
AWFULL !!!
I'm glad I didn't waste $99 on the full version... The first one I did wasn't bad except for the eyes but after that it crashes with unhandled exceptions most times I tried to use it. You can't move the autodots. After one successful save the torso disappeared and there was no head.
Not a bit disapointing VERY disapointing.
I hope this product is covered by the Daz return policy, they have around 30 days to sort it out.
S.
Steve, I just send you an invite to do a skype tech support. So far we were able to solve 100% of cutomer issues. About Autodots: try to reduce screen resolution - makes it easier to grasp/move dots.
If we somehow failed to solve your problem (most likely installation issue) after tech support, you are welcome to post negative comments. After.
Don't think this is an installation issue, especially with the unhandled exceptions all the files are in the correct place according to the PDF but I'll post a correction if that's the case. I'll contact you once I get Skype installed...
S.
A CORRECTION
A restart appears to have resolved the unhandled exceptions and other issues. Spoke to Laslo from Abalone who was most helpful and talked me through the application to make sure I was using it correctly and to give guidance on getting the best from it. Many thanks to him, if only all companies were as responsive and helpful.
S.
Question: will DIM install this automatically or will it require the plugin to be manually installed?
HeadShop and OneClick both come with a non-DIM installer. Installation should be painless to standard (c:/Program Files) or non-standard (b:e:f;etrc/xxx) Studio installations, as long as you select the right destination folder (DAZ 3D). Pls. read README or watch install video:
Thanks Steve! Skype/Screen exchange seems like a great tool to troubleshoot and resolve:-)
What's the best way to get a hold of Support?
Maybe as stated in the manual/readme: [email protected]. Or skype; skype name is lasloves, we are in California, any day, 8am to 7 pm.
