Looking for lighting solution product recommendation
Hi,
I’m looking for a good, comprehensive lighting solution for iRay. Something that is beginner friendly and doesn’t require lots of tweaking with the setting. As close to a one-click solution as possible.
I will be rendering mostly indoor scenes with one to five characters per scene. Mostly modern setting with some fantasy elements.
If anyone can recommend a product or products that comes close to these requirements I would very much appreciate it.
Thanks!
  • IceDragonArtIceDragonArt Posts: 12,966
    Try these Iradiance Light Probes  I use these 80% of the time for both indoor and outdoor.  Indoor, you may have to take out a wall or a roof that isn't in the scene but these are really solid hdri's.  And he has 5 or 6 expansions all of which I own and use.  You can turn the hdri part of it off in the environment tab (draw dome off)  They are hdri's so they arent like a studio light set up though
  • Thanks IceDragonArt. I did check those out as they are a good well priced also. I just wasn't sure what exactly I would be buying. These are just the light setup based on HDRIs right, not actual HDRI images that I can use as backgrounds or environments?
