Lips, eyes, nose sudden all increased in size.
Hello, I did something most recently and only remembered that DAZ3D prompted me to automatically install Default Resources which was weird because I was simply reloading a scene and it never prompted me to do it before. I do not know if this was the reason why but now every single one of my characters including the scene I did not reload (i.e. every scene) the characters lips, nose, and eyes have all been enlarged and I do not know what I did to cause this to happen. Please help.
  • nonesuch00nonesuch00 Posts: 18,863
    That sounds like somehow you have overwritten the original presets for those characters so that they are using the 'Cartoonized' for G8F/G8M's morphs applied to them but that's very unlikely. I have only ever had to installed the 'Default Resources' when I have new or reinstalled DAZ Studio.
  • Are you sure it's not just the focal length of your camera? Not that i can think why that would be persistent across scenes, but if the value were suddenly lower it would tend to produce the effect you describe.
  • That sounds like somehow you have overwritten the original presets for those characters so that they are using the 'Cartoonized' for G8F/G8M's morphs applied to them but that's very unlikely. I have only ever had to installed the 'Default Resources' when I have new or reinstalled DAZ Studio.
    This is basically what happened to all of my females. Males are unaffected.
    2544 x 2048 - 1M
    edited December 2018
    Yeah, it looks like a 'Cartoonized for Genesis 8 Females' head morph or a similar product has been partially applied and saved over the old preset; replacing the old preset.
    Select the Model that has too big facial features & then in the Parameters tab select 'Currently Used' it will show you which morphs are applied.
    Post edited by nonesuch00 on
  • AnonTurtleAnonTurtle Posts: 31
    Okay so this is really weird. 1 of the character head (lets call it Head X) was at 100%. Though it did not show up in Parameters or Shaping's "Currently Used". Searching for it will display it at 100% for Head X. Though I have no idea why it applied to every female character across every scene. Additionally, I did NOT set any character to have that Head X @100%. It showed up under Shaping>Currently Used but not Parameters>Currently Used. And this was only after I did a Right Click on Parameter>Zero>Zero Figure Shape.
    Finally, when I create any new female character (lets call it Head Y), Head Y is set at 100% like normal but Head X is also set at 100%! The only way I can think of to aleviate this issue is to remove that character completely. So I don't have to redo every scene and every new female character by having to set Head X to 0%.
    Post edited by AnonTurtle on
    This is an occasional bug that happens with certain characters, try unistall and re-install, and also flag it as a bug om the appropriate forums.
  • Has anyone solved this problem?
