FG 70's dForce Outfit for Genesis 8 Female- Hair?
in The Commons
Does anyone know what hair is used for this item https://www.daz3d.com/fg-70s-dforce-outfit-for-genesis-8-females ? Alternatively, does anyone know where I can get similar hair style (70s) elsewhere? I already own this https://www.renderosity.com/mod/bcs/70s-hair-for-g2f/113011/.
The mission is to achieve either this https://www.pinterest.com/pin/387661480418566533/ or https://www.pinterest.com/pin/387661480402974140/
I would really appreciate any sugestion on where to get the dress of that style as well
thank you
Looks like an OOT hair possibly; pretty sure I have it, so will look.
Edit:
Am thinking this one: https://www.daz3d.com/cathy-hair-and-oot-hairblending-2-0
It is easy to use on G8; either buy the new release that transfers hiars if you have a lot you want to transfer; or for individual ones, change the scene identification.
Hi nicstt
Thanks for the quick response. It does look similar to the picture, I might give it a try. The only thing I am afraid of is that my base model is G2f to which I am used to, all the clothing items are either for v4 or gG2F. Do you think if I change my base to G8 they will work?
Load your preferred figure, load your hair without fitting it to anything, parent it to the figure's head, use z-translate and y-translate and smoothing modifier to make it fit right. Select your figure, save hair as wearable item under G2F hair so that you can use it again later.
Thanks Odaa,
Very useful tips. Will give it a try
Try this for the hair
https://www.renderosity.com/mod/bcs/val-bebe-hair-amp-buns-3in1/84309/
Hi ALLIEKATBLUE
Yes, I have been eyeing that product too. But it look a little overboard with the volume.
Can G8F assests work baclwords on G2F e.g. the dress?
They can work and work well; they do vary though so would need to experiment.
If you buy it, dont like it; Daz are fine with returns - 30 days; you can have store credit or refunded to the method you used to purchase, just be specific when returning.
You could parent it to a G3 figure; match the morphs (approx) and the pose, then invis the G3 figure, I have found that to be more successful some of the time in the past then messing about with tweaking the position. It can also be slower too. :)
Thank you nicstt
Never knew about returns
In case you were interested, I think I found the hair and happy with it https://www.daz3d.com/twilight-hair-for-genesis-3-females
