Piercings for Genesis 8 Males
Noah LGPNoah LGP Posts: 2,617
edited December 2018 in Product Suggestions
Hi,
I'm looking for face/body piercings bigger than Neikdian's Piercings, they are too thin almost invisible in the render.
But thinner than Vunter Slaush's nipple piercings which are too big.
Post edited by Noah LGP on
  • vwranglervwrangler Posts: 5,045
    I don't know of anything specific for G8, I'm afraid.
    However, Neikdian's piercings are mostly props attached to rigid follow nodes, so they can be scaled larger, if needed. You'll need to move them around a bit after, but that's not too difficult. (For that matter, Vunter Slaush's are also props attached to rigid follow nodes, so they can be scaled smaller.)
    Other than that, depending on what type of piercing you want, it might work to use M4/V4 smart props and parent them to G8M. Cool Tuna has some old but still serviceable Poser props at their site: http://www.cooltuna.com/poser/poser-freebies.html
    Post edited by vwrangler on
  • KitsumoKitsumo Posts: 1,222
    Piercing is such a broad spectrum of things to cover and there are relatively few products on the market. It would be well worth your time to learn how to make your own. Just google daz studio rigid follow node tutorial (the best result is NSFW). Some basic modeling knowledge is required but it will pay off a lot.
  • Noah LGPNoah LGP Posts: 2,617
    @vwrangler
    Thank you very much for the link !
    Rescaling the props is a good idea but I think the diameter of the cylinder is still a little thin or big.
    Depending on the shape (ring, curved stud, ...), it's not always easy to obtain a good result.
    For example, the nipple ring.
    1. Black ring : Vunter Slaush's piercing, scale : 100%
    2. Blue ring : Neikdian's piercing, scale : 200%
    454 x 416 - 27K
    If you just need a ring, go to CREATE - NEW PRIMITIVE - TORUS and play with the settings till you get a ring the correct size and add a metal shader to it.
    @FSMCDesigns
    Good idea ! I didnt know it was possible to create a ring. Thank you !
