Can iRay Renders Be Farmed Out to Someone Else to Render?
I don't want to have to own a MAC and a PC.  Can you email or upload your iRay scenes to some company on the Internet to render for you?  Is there any way to do this?
Thanks!
  • The only way for that to work is if the company or persons who you sent the scenes to owns the exact same items & also had the same file structure as you do for everything that was in the scene.
  • It is possible to use Iray server remotely, that doesn't require tha\t the render machine have the content but it does require that the server not keep copies of the data once the render is done. If you wanted to send out scene files then as fictionalbookshelf says the other system would need to have licensed copies of the content isntalled (but the exact location of the content directories isn't critical - as long as the fiels are in a content directory, on the same relative path as on your machine).
  • Yes, there are Iray render servers available - PM sent.
  • FauvistFauvist Posts: 2,290
    Thank you!  I will check it out!
