Preview render interrupt work, when using mouse to move around. Very frustrating!
fableman
Hi.
Settings: Nvidia render in my Aux Viewport (preview window)
Problem: When I move around or try to change numbers using mouse to slide or any thing that involves mouse the Render kicks in and make the program totally useless!
Solution: Please Santa! Make the render only start after idle of 5 secounds, then atleast I have time to move around and set numbers correct without been interrupted all the time!
Now Iam forced to use other render settings in the preview windows and change back and forth all the time and this is soo frustrating when I need to see color change of textures or light settings!
Cheers!!!
You can always set your prameters then change the Viewport to Iray.
