Can I fix this or I’m out of Luck?
Turk_WLFTurk_WLF Posts: 177
edited September 2013 in Daz Studio Discussion
I have a number of vehicles that I got when I was using Poser 7 & they work great; I really would love to be able to use them in Daz Studio 4.6 Pro. However when I operate their parts like open the doors I got strange effects, I’m wondering if it is possible correct the strange effects.
Mainly the strange effect is the mesh stretches from opened edge of the door to the body of the vehicle.
I think these pictures can explain better than I can…
(The light background is Poser 7, the darker background is Daz Studio 4.6 Pro and the Vans are the same just loaded & doors openned)
Thanks,
1906 x 1018 - 187K
1040 x 743 - 38K
Post edited by Turk_WLF on
  • Richard HaseltineRichard Haseltine Posts: 111,382
    It may be that they were saved welded, relying on Poser to unweld them. If you have a modeller (I think Hexagon will work, though make a copy of the original OBJ first) select the doors etc. (you should be able to select by group or by material/shading domain, with luck), cut, then paste to place them back in the mesh but no longer welded. See if that fixes the issue with one of them, as a trial.
  • Turk_WLFTurk_WLF Posts: 177
    Richard,
    I hear what you're saying I'm fairly handy with Hexagon as far as modeling goes but the UV-mapping & the ERC side of things I make newbie look like a pro. However I'll see what happens.
  • barbultbarbult Posts: 27,501
    Someone posted a similar problem a few weeks ago. They contacted the vendor and got updates to the vehicles, which then worked fine in DAZ Studio.
    You shouldn't need to do any rigging - if you save a copy of the OBJ you can save the modified version over the top of the original and the CR2 file will load it. Any actual morphs would be broken, but vehicle models rarely have morphs anyway (things like master controls to spit the wheels, or to turn the steering wheel and steerable wheels together, won't be affected). I don't think cut-and-paste will break UV mapping in Hexagon, but I'm not certain of that (so it's definitely one of the things you should check before doing more than one model).
    http://www.daz3d.com/forums/discussion/27940/ is the thread I was referring to.
  • SloshSlosh Posts: 2,391
    None of these may be needed if you change the subdivision method to Catmark (Legacy). Should solve the issue
  • none01ohonenone01ohone Posts: 862
    edited October 2013
    Ha ha. A bald wizard Already!!! :-P
    Don't forget to roll up your trousers, er wait a mo, that's the Freemasons.
    Post edited by none01ohone on
    :) I haven't heard from you in ages. All's good, I hope?
    Did changing the subd method help, Turk?
    edited October 2013
    Fine thank's, Your store's starting to fill up nicely. Me thinks someone's been busy. Guess that's why we haven't seen many of your posts lately. Knew those SPEX would be well rec'd. Congrats. All the best and see you around in the forums.
    /EDIT same type of thing in this post:
