[SOLVED] Help bitwelder! Dialog Design won't generate code
Esemwy
Nevermind. Found the note that nested layouts are not supported. Might I suggest this as a future enhancement?
Help me @bitwelder, you're my only hope!
I made sure to create a dialog without buttons and used only supported widgets, I get the choose Cancel/OK buttons dialog, then nothing. No code, no error dialog, and the the script dialog becomes completely unresponsive (i.e. none of the buttons work any more). The only indication that something went wrong are a couple of lines in the log.
2018-12-19 09:42:45.804 Loading script: D:/DAZStudio/DAZ/Content/Scripts/Dialog Design/Dialog Design.dse2018-12-19 09:42:45.813 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-12-19 09:42:52.430 WARNING: general\dzscript.cpp(658): Unhandled error while executing script.2018-12-19 09:42:52.430 WARNING: QScriptEngine::popContext() doesn't match with pushContext()2018-12-19 09:42:52.432 Script executed successfully: D:/DAZStudio/DAZ/Content/Scripts/Dialog Design/Dialog Design.dseI've included the zipped UI file below.
If I'm doing something wrong, I'm at a loss. I'm using the latest general release on Windows 10, if that matters.
zip
zip
daz_test.zip
810B
Post edited by Esemwy on
