Deleted my library, now Install Manager won't start [SOLVED]
MarkIsSleepy
Hi all,
So I had some hard drive issues this week and ended up haviing to completely replace the drive that My Library was on. I decided to take the opportunity to move My Library to an external drive which I'd been wanting to do anyway, but now Install Manager will not start. I get the password screen, enter my password (or check "work offline," same issue occurs with both) and then Install Manager just hangs forever with a "not responding" message.
Was there something in the old My Library folder that IM needs to run properly? Or is something in IM pointing at the old drive and it won't start with that set? Is there a settings file somewhere for IM that I need to delete?
I'm on Windows 10 Home edition and installed Install Manager to the default location.
Anyone have any thoughts on how I can get Install Manager working again?
EDIT: Ok, this somehow fixed itself via the tried and true "Did you try turning it off and back on again?" method.
