objects disappear when zooming out
hi,
my objects in my scene disappear when I zoom out. I don't even zoom out very much.
i assume this is because of the near and far plane but I can not find any option to set these (I would also expect them to be automatically calculated).
any suggestions.
Peter
If you have the Near DOF Plane and Far DOF Plane Visibility set to 'On' in the Parameters pane, that could cause it.
You will find it in Parameters for the Camera that you are using, Display > Camera View > Depth of Field. Switch it to 'Off' or change the colour and Opacity of the planes so that you can see through them.
If it isn't DOF, can you please post a screenshot that will illustrate the problem?
If it isn't DOF then it may be an Open GL issue with displaying the UI. I get this a lot and it is very annoying. 99% of the time doing Ctrl Z (Undo) fixes the issue. 1% I have to close down DS and repoen.
