Daz Studio 4.10 will not run at all on Mac Pro Mojave
I had the main hard drive crash on me so I did a brand new Mojave install on my Mac Pro and Daz will not install at all. I managed to install the Install Manager for Daz, but Daz itself will not install at all.
I have a late 2012 Mac Pro and I installled 2 SSD hard drives, because one is not just enough for me, and the larger capacity SSD are way more expensive.
So on one SSD drive I installed the OS and on the other one I intend to install all the DAZ content. I need to mention that DAZ worked just fine in the same machine running OS Siera. Also I have all my DAZ Content save in the second SSD as well.
I have a Nvidia GeForce GTX 680 video card with the latest web drivers installed, that seem to work just fine.
The install seem to work just fine, just at the very end, while installing stopped for a very long time.
Finally installed, but the 32 bit version won't run at all. I understand that Mojave might have problems running 32 bit apps. The 64 bit version seem to start, however it stops at the "PowerPose Tool Loaded" message. The program freezes and I attached the crash report.
I can't figure out if it's something that I've done, or what would be the issue.
Thank you in advance.
643 x 482 - 605K
txt
txt
DAZ CRASH REPORT.txt
2M
  • TotteTotte Posts: 15,211
    Looking at the stindumno trace....
    Reality::RealityBase::RealityBase() + 462 (Reality_DS64.dylib + 2316622) [0x12651194e]
      27  Reality::RealityBase::main() + 2824 (Reality_DS64.dylib + 2319816) [0x1265125c8]
      27  Reality::RealityBase::findRenderers() + 145 (Reality_DS64.dylib + 2329537) [0x126514bc1]
      27
    Looks like Reality hangs, try to uninstall that plugin and try again, and if it works then, try to get an uopdate
  • Thank you so much for your help. The weird thing is that I did not had installed Reality yet. I tried installing it now, and got another crash report
    txt
    txt
    DAz Crash report.txt
    87K
  • After installing Reality it crashes even before loading. After I uninstalled the Reality plugins still does th same thing ... hungs up at "Power Pose Toll Loaded".
     Do you know if there is a way to uninstall/remove Reality manually?
  • PlatnumkPlatnumk Posts: 682
    edited December 2018
    Did you completely remove Reality as detailed here http://preta3d.com/wiki/doku.php?id=uninstalling_reality_4_studio_edition
    Post edited by Platnumk on
