Fitting old hair product problem
TheCediz
Hello!
This might not be a big problem, but can't seem to get through it... It happens with only some products, here I have an example of NJA ponytail hair for G2F that I try to fit on a G3F. The mesh is distorted at neck level and that part doesn't follow the head movements.
I tried fitting it as a short hair, shoulder lenght hair and none. I also tried to play in the scene identification parameters...
Have any idea for how to fix this? I'm sure you do ;P
Thx in advance
567 x 680 - 276K
Post edited by TheCediz on
Try not fitting it, but position it as well as you can, then scale it and use the adjustment morphs (if there are any for the hair) and possibly add a smoothing modifyer with collision target set to G3F, then parent it to her head.
Well that was easy. It works fine!
Thx a lot!
