Fireflies everywhere for no reason?
tcassattcassat Posts: 77
Hi!
Yesterday the software was working properly. But something happened with the render engine today and all the images look like this:
What I've tried to fix:
1. reboot computer (no results)
2. change render settings to CPU/GPU (no results)
3. turn off/on the fireflies filter (no results)
4. change hdri and illumination options (no results)
I did not make any modifications on my computer from yesterday to today. Yesterday the renders were working properly. Even using the same scenes saved yesterday, I still have this problem.
EDIT: I'm trying rendering a model without any prop. Normally the render would take 2-3 minutes on my PC, but after 8 minutes it had not gone 0%.
Post edited by tcassat on
  • Have you tried clicking the Defaults button in Render Settings?
    Yes. But the problem persists.
    Since I have not made any changes, I believe it is some flaw in the software or the hardware.
    To test the hardware, I only rendered with the CPU and only with the GPU, and both presented this same problem (which as I said before, it did not happen yesterday). So maybe hardware is not the problem here.
  • It is actually using the GPU?
    Yes.
    But when I select "CPU" in the "advanced" area of Render Settings, the same problem occurs. The only difference is that it takes longer to render. But these same artifacts appear.
  • If you look at the log (Help>Troubleshooting>View Log File) just after rendering what dose it indicate led it to stop - for example
    Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Convergence threshold reached.
    would indicate that it reached the convergence threshold.
  • tcassattcassat Posts: 77
    edited December 2018
    The renders never end. After reaching 50-60%, there is no more progress and it continues doing iterations until the time runs out.
    At this point, the image is full of fireflies, artifacts, I do not know exactly the name of it.
    Previously the convergence limit was reached in about 2 minutes for simple images. Now it is never reached and if I do not put time or iterations limits, the render never ends.
    EDIT: after reinstall the program, nothing changes.
    FINAL EDIT:
    I do not know what happened, but apparently the program is working right now. What I noticed:
    1. by setting the "view display" to Iray, it gets full of artifacts and fireflies (which did not happen before)
    2. the renders never ended
    3. I changed user in Windows 10 and noticed that the "view display" for iray is working properly
    4. I made a render on this other user and it worked
    5. I returned to my default user and the "view display" is still full of artifacts and fireflies
    6. I made a new render and ... it worked!
    I have no idea what happened, maybe some corrupted file on this other user, or maybe my hardware is dying. Anyway, I will continue to test to see if the problem has really been solved.
