What the...THIS is new!! Why is this happening?!?!
SLoTH_XVX
I loaded GEN8 Male base figure today and received the following error:
Then when I pose the figure in a sitting position this happened O_o
...and this...
I have used GEN8 Male MULTIPLE times and never had this happen until today.
I have installed no updates to Studio nor to the base GEN8 Male figure (that I am aware of).
571 x 530 - 39K
396 x 510 - 48K
459 x 303 - 24K
If you have this https://www.daz3d.com/anthropomorphs--manhippo-hd-for-genesis-8-male model from Alessandro AM installed, this could be causing the issue. De-install and try posing again.
SK
However there is a ManHippo update available since a month ago that should have fixed some JCM errors I made in the initial release.
That did the trick! Thank you SW!!
I am not sure I would have found this solution solo, I apreciate the help! NOw to DL the update from AM.
