New User - Error after Installing
I am getting this after message when trying to start the program after installing 4.6. I am a new user.
Does anyone know what it means and how to correct it?
DAZStudio.exe - Entry Point Not Found
The procedure entry point ?put_LastRecID@QueryResult@vsql@fbl@@QEAAXI@Z could not be located in the dynamic link library D:\3D Graphics\Daz\VClient_release_x64.dll.
OK
Thanks in Advance!
  • Richard HaseltineRichard Haseltine Posts: 111,921
    Is the DAZ Content Management System installed and running? If you are using Windows Vista or later, start Task Manager and check the Services tab; on XP click Start>Run type services.msc into the dialogue box to run the services applet.
  • edited December 1969
    Yes it is running.
    I'm not sure, then, unless it failed to update. You could try stopping the CMS (there's a shortcut in the Start Menu>DAZ 3D>DAZ Content Managerment Service, then uninstall the CMS (also has a shortcut in Start) and then reinstall (if you have the Install Manager, go to C:\Program Files (x86)\DAZ 3D\DAZ3DIM1\cms to find the installer).
    Thanks for your input, I've tried the items you've suggested, but no success so far. I'll keep on looking.
    I was able to install the 32 bit version instead of the 64 bit. This isn't a great solution, but I guess it's a start.
