During Sitting Pose, Bones in Pelvic Area Disrupts
in New Users
Hello,
When I try to pose the Genesis 8 Female Figure to sit (or any other figure in this respect), the pelvic area takes a strange shape. I couldn't figure out what bone is it causing this problem. (Can be Pelvic bone, sacral bone or spine?)
Screen shots of the smooth shaded model is in the attachment (I do hope showing them in this form is not a violation to forum rules.)
Could you please help me solve this issue?
Thank You.
436 x 482 - 81K
866 x 501 - 182K
843 x 472 - 114K
846 x 498 - 178K
I believe that is an issue with https://www.daz3d.com/big-girl-morphs-for-genesis-8-female - assuming you do have that installed is it a freshly downloaded copy?
Hello, it isn't freshly installed. I looked for hidden parameters and I assume a parameter in that package.has a wrong default value. I fixed it and problem disappeared.
Thank you for help :)
It's not a wrong default, it's that there is a correction morph that was always on instead of being on only when the main morph was applied. I think if you redownload and install it will be fixed without needing to adjust anything manually.
