Writing a function for "Timechanging"
Hello,
I wrote a function which modifies the scene when the time changes in Daz Studio.
If I start the script, nothing happens.
I have to add an infinite loop after the definition of the callback to see my function working correctly.
This method works fine, but I have to kill this loop before to close The Daz Studio application. Otherwise, it stays in memory.
My question is :
Is there a way to make this function integrated in the Daz Studio global loop?
I thank you for your replies.
Gérald
You may want to look at callbacks - several sample scripts here, and in the preceding section http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start#post-load_callbacks
Hello Richard,
Thank you for your reply.
I tried to use a callback and this works fine.
I define the script name, I define the CallbackMgr, I define the Callback using
"oCallBack = oCallBackMgr.createCallBack( "Update Time", sScript, false );"
Then I define the connection using
"oCallBack.setConnection(Scene, "TimeChanging(DzTime)" );"
In these lines, I do not find how to have a relation between this connection and the DzTime used in the signal.
I needed to use "TimeChanged(DzTime)" signal to do my node update at the right frame because I did not find a way to reach the newTime defined in the signal.
I just have a question.
How is it possible to define a relation between the signal parameter(s) and the connection?
Thank you very much for your help.
Gérald
I'm not sure what you mean by defining a relation.
Hello Richard,
you are right this word is a bad choice, a link, if you prefer.
I will give you a example using one of your samples.
var sScript = "support/CallBackExample/HelloWorld.dsa";
var oCallBackMgr = App.getCallBackMgr();
var oCallBack = oCallBackMgr.createCallBack( "Hello World", sScript, false );
oCallBack.setConnection( Scene, "nodeAdded(DzNode*)" );
- sScript is the filename of a script.
- oCallBack is a callback defined with the previous script.
- setConnection works a little bit like the "Connect" function for a signal, but the signal define a function with a parameter, not a file.
Now, I want to use just created node in the "HelloWorld.dsa" script, my question is how can I get it?
I certainly do something wrong, but I do not understand what.
Thank you for your help.
Heh, those are Rob's samples. I'm not at all sure of the answer to your question - or if there is one. Sorry not to be of more help.
Hello Richard,
no problem, do you know I would have the ability to contact Rob here.
I could reply to my other thread in the SDK but I am not sure he will read the thread again.
Personally, Have you a way to contact him?
Gérald
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/elements/callback_rendermgr_active_renderer_changed_property_current_value_changed/start
Thank you Chohole,
I will try this sample and I will tell you if I managed to get arguments of the callback.
Gérald
