Questions about DAZ
CleasyClaire
in New Users
First I would like to say hello and nice to meet everyone here. I have tested daz somewhere in the past but it was a long time ago and I don't remember much about this program and I have a few questions about how to run daz properly:
In my pc I have only one hard disk splited into two partitions C and E. I would like to install Daz and all it's content to E, is this possible and if yes how?
I have purchased a long time ago some softwears for daz(like bundles or contents) how do I install them?
In Daz how do I browse to find my custom content?
I hope someone can clarify this for me thanks!
Download and install Daz Install Manager, enter your email (the one you use to log into Daz), and choose Work Ofline. You can then click the gear icon at top-right to open the Settings dialogue and edit the install and download locations in their respective tabs to use the E: drive. Once done you will need tot ell DS about those -the simplest way is to download http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start (there's a link just above the box with the script) and drag that file into the DS viewport while it is running.
Thank you for the answer but I have a few questions:
1) which app should I install first? Daz studio and then manager?(I did like this but to make sure I followed the right step) ( I had also checked 'offline work' but it doesn't work either)
2) I installed first daz studion then the manager but I am not able to install/select the custom content I've saved in my pc
3) What is the folder that I have to put my custom content in E partition?(I tried to put by myself in C or E but I got the error when tried to load in Daz, like it doesn't recognize the custom content) Neither the basic content is working. I am aware that I am a bit lost so I need help to understand and fix this issue. In C I don't have enough memory as I told you in my first post so therefore, what should I do?
