Clothing with muscle morphs
Sir RenderSir Render Posts: 0
I have loaded Victoria 4.2 into my scene.
I have applied the Victoria 4.2 Muscle Morphs and turned up the "Gymnast" dial.
I have applied the V4 Ranger clothing to Victoria.
With the muscle morphs, the clothing does not fit.
I have looked for some way to adjust the clothing, but have not found anything.
Is this a one-or-the-other deal?
Can I use the Muscle Morphs *OR* the Ranger clothes, but not both?
Thanks in advance.
  • Sir RenderSir Render Posts: 0
    I don't know if I have stumbled onto the solution, but it looks like "Magnetic clothing" is the solution?
    This seems to make the clothing grow and shrink with the muscle morphs.
    If there is some other way to adjust the clothing, I would still be interested.
    Thanks.
    You can get Dimension3d's Morphing Clothes from Rendo and use it to copy the muscle morphs into the clothing, too.
  • Richard HaseltineRichard Haseltine Posts: 111,947
    Magnetise clothing is not related to fitting to morphs, and if you are using DAZ Studio should be done automatically anyway. If you are using DS 4.x, right-click on the morphed figure and select Transfer Active Morphs from the context menu.
    I am using DAZ Studio Pro 4.6
    When I put the clothing onto the V4.2 figure, the muscles that were morphed protruded through the clothing.
    Magnetize clothing made them fit to the skin. However, that may have been coincidental. I will try the Transfer Active Morphs option.
    Thanks for the replies.
    I tried the "Transfer Active Morphs", but that did not help. I was, however, able to right-click on an item of clothing and choose "Fit To ..." which opened a dialog where I could select "Victoria 4.2" from a pull-down menu and the item adjusted to fit her morphed body.
    Ah, sorry - I was taking it for granted that the clothing had been fitted. Yes, that is the necessary first step to get morphs and poses to transfer to the clothes.
