Modifying the vertices of a geometry from a binary file
Hello,
I write a program which animates a node in Daz Studio.
When I want to transfer this animation to Daz Studio, the speed for this transfer is very slow in script.
I just started to write a plugin which allows to accelerate this communication by using binary files and the SDK.
My script calls a plugin function which executes this update.
My problem is I do not find a way to perfectly update the vertices in the SDK.
The vertices are correctly updated but the normals stay the same by using directly a DzVertexMesh class and without using a DzGeometry class.
In script it is possible to call the "setVertex" function of a geometry, In the SDK, I did not find the method.
Why I start this thread here : because my base program is a script, because my thread in the SDK forum has no reply since one week and I think the script forum seems more reactive and because I think programming competencies are in the two forums.
Thank you by advance.
It will avoid dupliation of effort if you keep the discussion in your original thread https://www.daz3d.com/forums/discussion/293531/importing-an-animation-using-a-binary-file
Hello Richard,
you are fully right but I started this thread because I didn't receive replies in the SDK forum.
Rob proposed me 2 solutions and I found another one.
I explained this solution in the SDK forum.
I hope the solutions provided by Rob and my solution could be helpful to SDK developers.
Sorry for the useless time I asked you
Gérald
