High contrast rendering ?
in New Users
Hello !
i have a question, i'm trying to get a high contrast rendering in daz studio, i would like the dark very dark and light very light, i've tried to put only one light source at the side of my character, it works fine i have a nice shadow but once i start to rending the shadow is not that deep, i tried to tweek the exposure value but it's not this i think because it makes just everything white or everything dark but doesn't increase contrast.
where could i find this option ?
thank you ! :D
Are you working with 3DL or Iray?
If you aer using Iray make sure you have the Environment Mode set to Scene Only in Render Settings, otherwise you will get the HDR lighting everything. You will then need to adjust Tone Mapping - and will find the render fairly slow and possibly prone to noise.
ah yes ! thank you yeah i was using Iray but i wasnt on scene only in render settings, now i got already much more contrast, i will check what i can do more with the tone mapping ! Thank you !!
