Render Size - solved
FWIWFWIW Posts: 320
edited December 2018 in The Commons
Is there any way to raise the max render size? I need something rendered at 24,000 x 18,000 ( specifically 60 X 80 at 300 dpi, I was commissioned for art for a blanket and that is what the printer requires) which I expect would stop my pc from being usable for a week but is tolerable. But the highest I can get it is 10,000 x 10,000. Is that the max for DS or is it my pc or something I am doing wrong. I was SURE the max was higher than that before.
Post edited by FWIW on
  • AnotherUserNameAnotherUserName Posts: 2,727
    Find the little cog wheel in the upper right hand corner of the Pixel Size (Global) setting in the iray editor menu. Click it. Select Parameter settings. On the right hand size of the menu, uncheck Use Limits and accept. You can now go above 10000x100000. Hopefully that works for you.
    Post edited by AnotherUserName on
  • FWIWFWIW Posts: 320
    Thank you!
