Need a Stadium
https://www.turbosquid.com/3d-models/lwo-football-stadium/930309
There are 4 versions in that link, none of which fully work in Daz3d. I am willing to drop $20 on the first person to get one to work in Daz.
Maybe an HDRI would work? There is one at HDRI Haven;)
The best stadium I know of offhand is the Truforms Stadium at Renderosity.
https://www.renderosity.com/mod/bcs/truforms-stadium/116621/
And at the moment, it costs $20, so there you go.
Works just fine in Studio, even though it's built for Poser, but most Truform/Trustyles stuff does fine in Studio. It's a soccer stadium, but something like this will help to turn it into an American football field, if that's what you need:
http://www.sharecg.com/v/20902/browse/11/Poser/Football-Goal-Post
http://www.sharecg.com/v/20875/browse/6/Texture/Football-Field
http://www.sharecg.com/v/40082/browse/5/3D-Model/American-Football-Field-for-Poser-and-DAZ-Studio
http://www.sharecg.com/v/40084/browse/6/Texture/Textures-for-the-American-Football-Field
All Poser, but easy enough to use in Studio.
There are also some older freebie Poser stadiums at ShareCG. They have a few scale/construction issues, but can work for more distant renders.
http://www.sharecg.com/v/40210/gallery/11/Poser/building6-Football-st
It's the running track around it that I need. Not independant, but as part of the stadium for the graphic novel I am about to start.
I'm hoping that someone knows how to fix the current file listed.
It's quite an easy fix.
You're going to need Blender for this, but don't worry, if you've never used the program, you're not going to have to do anything but import and export again.
- Download the Obj version of the stadium
- If you haven't installed it yet, you can download a free copy of Blender at: https://www.blender.org/download/
- Once installed, launch Blender.
- click on file > import > Wavefront OBJ
- select the stadium
- click file > Export > Wavefront Obj
select a new name.
- in the bottom right-hand side of the export window, you will see a bunch of export options. One of those options is Triangulate faces. Make sure this is checked. I've included a screenshot.
- now go into Daz Studio.
- click file > import. Select the new stadium
- in the import options dialog, under "from," choose Blender.
Under axis conversion > vertical Y: change "Z" to "Y"
you should be good to go, although the textures are noticeably tiled, so you may need to remove them from the diffuse channel to get it to look like the original promo image.
I've included a really quick and basic 3delight render.
there is this too, maybe with some minor adjustments
https://www.daz3d.com/velodrome-track
It gives me a ghost. I can see the yellow outline if my cursor is over iit, but otherwise it's not there. Can you upload the OBJ file you have?
Too bad I'm not doing a Rollerball story. That would be perfect. :)
I've sent a PM
Got the file, got it imported. It was 4 times too big, but that was easily fixed in Daz. The lines for the field are above the actual grass, but I can deal with that, too. It works!
Thanks everyone for your help and suggestions!
