Genesis 3 Turns Grey when Shader added
Like it says in the title, I add on of the included shaders (orange toon) and it turns gray, cannot figure out why.
  • LyonessLyoness Posts: 1,641
    would you please post a screen shot, describe the shader you are applying.
    make sure it's a rendered shot.
  • Ok, I made sure I got the Daz core and the render window in the same view here.
  • What shader is that using? I can't see the path in your screenshot - if it's a custom 3delight shader it probably won't convert to Iray, giving a grey, default material render as a result.
  • Not a custom, it's the included "Orange Toon"
  • barbultbarbult Posts: 27,518
    Orange Toon is a 3Delight shader.
  • I didn't mean custom as in made by you, I meant custom as in not oen of the shadrs (Daz default, AoA SSS Shader, maybe one or two others) that DS will covnert to Iray Uber Base.
