Towel Set for Genesi crashes daz when applying 'fluffy white shader you diffuse'
Serene NightSerene Night Posts: 17,705
I've been having trouble using this set. It lets me load the towels just fine on the character, and the majority of towel shaders work well. But when I apply the "fuffy white shader you diffuse" it causes daz to stop responding forcing me to quit.
I am using daz 4.6
I can apply other shaders, and so I know its something with this file. Does anyone else have this issue?
    I have just tested this, and it works OK for me.
    There are four icons in the library concerning the 'Fluffy White Your Diffuse' shader, One of them says 'Use alone, do not combine with any other shader', and it can be used to remove any other shaders. There is also an icon to remove the Fluffy shader before saving the scene, so it may cause problems in some instances I think.
    I have tried it on several of the towels, and it has not caused problems, but I think you would need to remove any other shaders first before applying it.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Which exact version of 4.6? it worked just now in 4.6.0.18 (the production build).
    It is 4.6.0.18
    I was able to get it to work once.
    Subsequent tries, just cause it to hang with "daz studio not responding" . (see screenshots).
    1920 x 1080 - 482K
    1920 x 1080 - 464K
