Using Iray to texture, do I dump the ROUGHNESS MAP?
Texturing a model.....
It comes with many maps...the Only one I can't find a home for is the Roughness Map.
Is that for a different rendering engine and should I ignore it?
Or is that a synonym (for a different map) and it's important?
Help!
  • Eva1Eva1 Posts: 1,249
    You can use a roughness map instead of a specular map. Just put it in the glossy roughness image slot.
  • Griffin AvidGriffin Avid Posts: 3,882
    edited November 2018
    I have a specular map already. So basically, I can just ignore it, then?
    Tehre's two open maps....
    Bump Strength and Displacement Strength....
    Any of those two a factor?
    They are currently empty.
    Post edited by Griffin Avid on
  • Matt_CastleMatt_Castle Posts: 3,249
    Specularity and roughness are not the same thing. The former controls the amount of reflected light, the latter the sharpness of it. (Or, in other terms, the brightness and size of the highlight).
    If you have both texture files already, then it doesn't make sense to only use one.
    Post edited by Matt_Castle on
  • I'm confusing myself.
    I have a Color map for Diffuse Color.
    Normal for the Normal map
    Spec for Specular
    and a ROUGH Map. I have no idea where that goes.
    Most likely, "Glossy Roughness", although it does depend rather a lot on where you got the original file. Different rendering engines encode and use the information very differently.
  • Thanks all. That gets me going.
  • RafmerRafmer Posts: 564
    If you are using the metallicity/roughness approach use the roughness map only, remove the specular. If you are using the glossy/specular use only the specular.
