How do i make an object texture lighter in Iray?
I am far more familiar with 3Delight use of the diffuse channel, but i am trying to work with Iray now.  But i can't figure out how to make a texture look lighter (or darker).  There are so many technical terms i am not familiar with!  I don't even know what to look for in articles.  Help!  I'm sure it is very simple--but i'm not grokking it.
  • felisfelis Posts: 6,502
    Base color is what is closest in Iray to diffuse in 3DL.
    It is long ago I have used 3DL.
    But there are many ither channels contributing in Iray to how the surface will end up. And be aware that there can be quite a difference from preview to rendered.
    This is in my view a good overview of the surface tab https://www.deviantart.com/sickleyield/journal/Iray-Surfaces-And-What-They-Mean-519346747
    But if you just want to shade something darker, you should be able to just set the color in Base Color darker.
  • marblemarble Posts: 7,500
    Another IRay surface parameter which affects how light/dark a surface appears is the Translucency Weight. I often tinker with that before the base colour (I'm mostly talking about skin here but I guess the same applies to other materials).
  • Rhank you very much--this is an excellent start for me!
