How to take all of the Background/Ground away? SOLVED!
squirtsquirt Posts: 208
edited November 2018 in The Commons
Hello Daz Gurus
I was curious how to take away all of the background (ground included) so that the only thing you are left with is the figure itself?   That way the figure can be transported to Photoshop for collaging.. Currently I keep getting a background color that winds up in the figure's hair. Then I'd have to spend hours brushing out all of the color trapped in the hair strands.
As always, I appreciat you all's help.
Post edited by squirt on
  • Carola OCarola O Posts: 3,862
    If you are using Iray when rendering, turn off Draw Dome Possible also Draw Ground, but I think that is only if you want to turn off shadows to a degree, I may remember wrong though.
  • JOdelJOdel Posts: 6,322
    uncheck 'visible in render'. Pretty sure it's in the Display section of the parameters tab.
  • scorpioscorpio Posts: 8,533
    squirt said:
    Hello Daz Gurus
    In Iray set Draw Ground to off (unless you want ground shadows), if using a HDRi turn Drawn Dome to Off, render and save as a png.
  • squirtsquirt Posts: 208
    All of the other suggestions just leave a black  background which gives me the color black to contend with as puts me back at square one...
    Where is this Displace section yo uare talking about?   I'll try that next.
    You  have to have the background item you want to turn off selected in the scene tab first.
    Plus, I don't know how it works in Iray. I only use 3DL.
    418 x 592 - 46K
    Uhm.. What version of Daz are you using because I don't see those options.
    1768 x 2160 - 915K
    DS 4.10.123
    Note: I just opened up a scene and tossed the old MilEnvironment into it an d then selected that. So the first item in the list 'Environment' is the name of the item.
    Post edited by JOdel on
    DS 4.10.123
    As you can see above.. I don't have those options and I'm using the same verson as  you are it would appear.
    Anyone else have any ideas?
  • TaozTaoz Posts: 10,371
    Not really sure what the problem is. Here's a character with hair, saved as PNG. Imported into photoshop the background is transparent so I can change the background color as I like.
    499 x 584 - 75K
    499 x 584 - 77K
    Ok, So just save as a PNG file.. Who would have thought that it would be that easy???
    He, he, thanks!
    squirt said:
    The problem is that I don't know how to do it.    How do you save it as a PNG.. What are the steps?
    Render in a separate window, there is a button to the right of the file name field where you can select file format when you save.
    616 x 90 - 7K
    Post edited by Taoz on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    And do the Draw Ground and Dray Sky have to be turned off?  Little things like that.
    When you go to save your render, there is a drop down box to select file type. .PNG saves it with a transparent background as long as you don't have an object or HDRI in the background
    edit: Taoz beat me to it.
    1509 x 154 - 88K
    Post edited by FSMCDesigns on
    Thank you!
    Thank you !
