Clothing splitting after applying poses
Hi
I'd love to ask for your help - I've started creating my first clothing and applying them to Daz3D models - so excuse the noob question: When applying poses, there is a distinct split betweent he left and right legs; would somebody be able to point me in the dierection to a tutorial or the manual in order to fix this problem?
Best wishes
M
Post edited by marc-2742448 on
I don't know what 3D software you where using to create this, looks great btw, but you need to connect the mesh. It seems like the parts are not properly 'sewed' together at the seams, the mesh needs to be once piece. You can't fix this with DazStudio you need to use another 3D modeling software to repair the mesh then repeat what you have done to fit the clotihng on the figure.
Depending on the 3D modeling software its also caled 'merge' or 'weld', in Blender the button to fix this is called Remove Doubles. The mesh points of the parts can perfectly match at the seam but if they are at the same position this dosent mean the points are connected automaticly.
If this is made in Marvelous Designer (and it looks like it may be) you need to make sure and export as Thin/Welded
