Are these needed? Genesis 3 Female Expressions
Can you make expressions without this?
https://www.daz3d.com/genesis-3-female-expressions
  • since I don't own them and I have expression sliders I guess you can
    I think those use HD morphs though
  • it does seem to have a large variety though
  • kenshaw011267kenshaw011267 Posts: 3,805
    edited November 2018
    You can make expressions by hand. Each figure comes with some built in and you can pose each face by hand.
    Post edited by kenshaw011267 on
    I don't have the expression pack you posted about, but I do have several other packs that came with pro-bundles, and most of them are so exaggerated I never bother using them. Save your money for more important things, and enjoy the satisfaction of dialing your own expressions!
  • PippenPippen Posts: 265
    yes
  • HavosHavos Posts: 5,701
    I am pretty sure the Genesis 3 expressions do not use HD, only the Genesis 8 ones do, which is what makes the Genesis 8 expressions look better.
    To answer the OP, no you do not need the expression pack to set expressions, you can use the individual face bones to recreate the expressions yourself. Having said that, it would take ages to recreate all the same expressions yourself, and unless you really want to do that, I would strongly recommend buying the pack. Bear in mind that this is a Daz Original, and is quite old, so is fairly frequently on sale at a steep discount.
    The expression pack, along with the head and body morphs are (IMHO) the three main must have products in order to use a particular Genesis base figure.
    If You plan to buy other expression packs, it might be worth to check if they come as independent or if they need the above as a base.
