Removing geometry from models
Hi All,
  Just wondering if anyone knows how to removr portions of geometry from packaged models. For example I would like to remove the side walls and footer lights from The asian Stage model completely. I realize that I can just turn off visability, but I just want to save the the base stage as a prop without walls or curtains. Thanks!
  • LeanaLeana Posts: 13,507
    If it's actually one single mesh you should be able to do that with the Geometry Editor in DS.
  • kwanniekwannie Posts: 870
    How do you actually remove geometry with the the geometry editor?
  • barbultbarbult Posts: 27,506
    Select it, turn visibility off, delete hidden polygons.
    barbult,
         Where exactly is the delete hidden polygons option found? When I go the tools drop down and select geometry editor I only get a red circle selector in my scene, and I right click I just get more selection options. I don't see any action options after that. Is there a geometry editor console somewhere in DS?
    Ooops, OK I found it!!
    I deleted hidden polygons and saved the Stage  as a prop, but when loaded the created prop, the names of the geometry I deleted still shows up in the scene hierarchy window with a liitle bone symbol next to it.  Is there a way to remove the deleted items from the scene hierarchy also?
  • Bones can be removed with the Joint Editor tool - select, then right-click in the Viewport and I think it's in the Edit sub-menu. However, be alert for possible consequences - and note that a bone without geometry isn't going to affect rendering since the rigging information isn't sent to the renderer.
    Thanks Richard, I fumbled into the joint editor and deleted som bones. I found out I can't just start deleting without knowin what the bones do. I also found out I can't scale the leftover geometry after all the deleting as I thought I would be able to. Maybe if I save the final geometry as an object and inport in then I will be able to scale in all directions. Thank you for the feedback!
