Very Large Facility Set... A very large background set for big scenes
McGyverMcGyver Posts: 7,103
edited September 2013 in Freebies
Very Large Facility Set: http://www.sharecg.com/v/72034/view/11/Poser/Very-Large-Facility-Set
A very large and open, formed concrete set meant to serve as a background for very large models or as a hanger or giant warehouse. Perfect for any render where a large ugly concrete background is needed.
Over 752 Feet/229.3 Meters Wide, 288 Feet/87.8 Meters Tall and 682 Feet/207.8 Meters Deep.
Big enough to store several 747s or millions of Lemmings, This model is just what you need if you've been hoarding Jumbo Jets or armies of lemmings.
Constructed almost entirely of UberDuraCrete™,a virtual durable* concrete-like product recently proven not to cause cancer in laboratory giraffes**.
UberDuraCrete™ will never need repairs unless you choose to repair it. Guaranteed for the lifetime of a fruitfly, UberDuraCrete™ will probably never cause this structure to collapse and will stay smelling springtime fresh!
The Very Large Facility Set is grouped and parented so as to allow you to turn off: the right wall, the left wall, the columns and the floor if you need to.
The Very Large Facility Set also comes with a separate un-parented "plain" floor section in case you do not want or need the recessed area in the center.
The Very Large Facility Set was designed as the background for my Wakefield Zeta Pulse Reactor Mk.67. The WZPR-Mk.67 should load centered on the recessed area, if you should choose to use the two together. For all other uses you may need to move the model up along the Y-axis so the model is level with world center. If I haven't spaced out entirely there should be a "ReadThisToo" file with some info on how to do that in case you are not sure, plus I think it also has the amount you should spin the dial to get it up to world center... something like 58 point something with numbers in it... I could look it up but that would rob you of the fun of reading.
Manufacturers notice: SilCorDyne Industries does not guarantee user satisfaction or safety.
*Durability as defined by our legal team so as imply the accepted meaning of the word, while retaining a completely separate and opposite
meaning bearing no similarities whatsoever to the standard definition of “durable”.
** Tests have concluded, with the exception of giraffes**, that long term casual contact with UberDuraCrete™ will cause cancer, leprosy and flatulence in most terrestrial land mammals, lizards, insects, birds and almost all aquatic life forms. UberDuraCrete™ is a trademark of SilCorDyne Industries LTD. UberDuraCrete™ and all its various formulas are property of SilCorDyne Industries LTD. which limits the use of the word UberDuraCrete™ by its discretion and whim.
Misuse or unauthorized use of the word UberDuraCrete™, will be be considered copyright infringement, slander and attempted homicide, to which point SilCorDyne Industries will seek compensation and prosecution to the full extent of the law and but not limited to the use of deadly force. Use of the word UberDuraCrete™ is limited to written words, spoken words, thought, and implication by use of hand puppets.
800 x 722 - 116K
1000 x 554 - 208K
1000 x 902 - 226K
1000 x 902 - 345K
1000 x 902 - 243K
Post edited by McGyver on
