Distributing my own morphs - G8 ??
How do I prepare and distribute my own custom moprhs (genesis 8)
I have just started to use genesis 8 Female and am currently building up various morphs for her using Blender. I have exported the default base figure from Daz as a wavefront obj, Imported into Blender and created my morphs.
After importing my newly created morphs back into G8 in Daz, all my morph dials etc work fine and as they should, so all is good so far.
Now, I'm thinking maybe other people may want to use some of my morphs, so I have saved as Support Asset - Morph Asset(s) called EXAMPLEmorphs. Do i now just zip up the 'EXAMPLEmorphs' Folder (from... \data\DAZ 3D\Genesis 8\Female\Morphs\EXAMPLEmorphs) and give it out??
Is this the correct/legal way to do it?. . . Do I need to do anything else??
Thanks
Ideally you put the full path - starting with the data folder - containing only your own fiels in the zip, that way Windows users can just merge it. You can set up a new content directory, then in the options dialogue when saving the morph asset set that as the base directory at the top. if you also put textures in the Runtime/textures folder (before applying them) and save your presets to that content directory then you should end up with all the needed files, and no third-party files, in one place ready to zip up.
Nice one. . . Thanks Richard
