Panorama's like views in Full HD
DjPokeDjPoke Posts: 6
edited December 1969 in Bryce Discussion
Hi,
I'm trying to make panorama's like views in Full HD (2 x 1920 by 1080), but i encounter problems.
1) When i select, for exemple, a 32/9 screen proportions, the upper and lower part of th screen is missing in 3d view.
2) As the defined screen is the working area, in top view, i can't access all objects i move at the right of the screen.
So, my question is : Can i scroll all the elements together to see them, or move them together in any view ?
  • HoroHoro Posts: 11,740
    @DjPoke - you could set the document size to the desired aspect ratio at half size so it fits the GUI and lets you work on the scene. In the same dialogue, you set Render Resolution to 2:1 and the render will have the desired size. In the wireframe view, you can move the view around using the hand and the zoom-in zoom-out tools near the bottom right corner of the GUI.
  • DjPokeDjPoke Posts: 6
    Thanks a lot for you help, Horo.
