Alembic Export - Broken UV maps
tz2016tz2016 Posts: 10
edited November 2018 in Daz Studio Discussion
Why when you export an Alembic without subdivision are the UV maps broken?
It seems like the normals flipped issue has been fixed in the beta.
MDD works correctly with subdivisions but I'm having to use C4D R20 which doesn't yet load MDD caches.
Post edited by tz2016 on
  • wolf359wolf359 Posts: 3,936
    Has keith youngs riptide pro been updated for R20??
    I am  still using it  with an older C4D version for My MDD exports from Daz studio
  • tz2016tz2016 Posts: 10
    No, not yet. I think C4D R20 really changed the way plugins can be coded, I guess causing delays in updates.
    The render farm I'm using only has the version of octane I need in R20, not R19.
    But the alembic exporter has always done this with subdivisions, I just problem solved using by MDD instead. MDD is probably a better option in many cases it doesn't mean alembic should not work correctly.
