Random white specks in IRAY renders
Ryuu@AMcCFRyuu@AMcCF Posts: 806
I'm not sure what I'm doing wrong, but my renders keep having random white pixels scattered over the entire scene.
Also, I'm trying to create a skid mark effect on the ground behind the griffon to show how far he traveled when he crashed slid landed.
The preview looks good, but the render is rather lacking.
image image image image image image image
I hope someone can help with this. Thanks.
Ryuu
2048 x 1152 - 2M
1091 x 996 - 183K
501 x 993 - 44K
512 x 4816 - 530K
399 x 325 - 28K
377 x 1285 - 154K
394 x 631 - 59K
396 x 1729 - 166K
Post edited by Ryuu@AMcCF on
  • Your preview is Texture Shaded and not Iray.
    Did you already tried to change progressive settings? Set an higher Max Samples/Max Time and maybe Rendering converged ratio to 99%
  • glaseyeglaseye Posts: 1,312
    A bit of an 'educated guess', but that noise is probably caused by the 'TD3_Atmospehere' object in the scene. AFAIK, that is used for 'atmospheric effects' like light rays etc. It does take a lot of iterations for the noise to clear, and thus alot of time (esp on cpu only...). Try hiding or deleting the 'td3...'
  • KitsumoKitsumo Posts: 1,222
    Yep, I recognized that scene as soon as I saw it. I had the same problem. Never did figure out a solution other than hiding the atmosphere.
    As far as skid marks on the ground, OP, you could try using a deformer to make depression in the ground, or make a displacement texture, but that would probably increase render time with such a large mesh.
