Use Install Manger Correctly ?
Hi. This is my first time I use DIM and I don't know why is not working correctly !! First, my Daz3dStudio version is 64bit, and DIM version is 32bit last version. Now I have some models from "porsimo.net" and I don't know why is not showing in DIM ? So, how to install it correctly ?
DIM works only with certain specially prepared zips - most, but not all, from Daz. General zips for freebies or from other stores will not work.
OK. I will try zip and 7z. But where to put these file ? The correct folder ?
The Runtime, Data, and any other foldrs at the same level in the package need to merge into the corresponding folders in a content directory - My Library, My Daz 3D Library, or whatever you use.
I notes something strange. The "My Daz 3D Library" im DIM path is not in my system ? How to solve this ?
Open Public Documents folder, Windows OS is adding "Public" to the name when viewed in Explorer.
I tried to see this folder in exploerer but nothing appears ? What else or option can help me ? If it could be simple like blender (just load zip file and DONE)
