Two Renders happening again? [Solved]
AbnerKAbnerK Posts: 718
Hi. This has happened before and I didn't get any answers but I'm on a brand new computer with an up to date OS and I'm still seeing two renders going on. I did a scene last night. It should have been done in 3 hours (but looking at the log my computer kept going to sleep, I think I've stopped that, it's a new OS a different settings) After realising I didn't like the direction of the eyes I started a spot render immediately after stopping the main render. I went out for an hour, when I got back the tiny snippet around the eyes was looking little better than after a couple of minutes. I looked at the log to check my computer hadn't got to sleep again but this time it appeared that the DS was doing two renders again. As before I only have on preview window which is in Iray and as usual it hasn't rendered anything during the spot render. It looks, from looking at the log, like it was continuing the main render from before. So, I cancelled the spot render and restarted DS.
After restarting DS and loading the scene I'm doing the same spot render. It seemed to be going well then after 30 mintues I cam back expecting it to be finished it looks no better than after a couple of mintues again. The log file looks like DS is doing two renders still and as if it is still doing the render from last night. How, what's going on? It doesn't always do this. It's been really quick for a while. Even before I got my new computer renders were going really well apart from the odd glitch.
I've attached the log file starting from the restart and in case anything thinks it will help I've attached a copy of the original, entire log file (the second one, on right)
Brand new
 Model Name:    MacBook Pro
  Model Identifier:    MacBookPro14,1
  Processor Name:    Intel Core i7
  Processor Speed:    2.5 GHz
  Number of Processors:    1
  Total Number of Cores:    2
  L2 Cache (per Core):    256 KB
  L3 Cache:    4 MB
  Memory:    16 GB
  Boot ROM Version:    184.0.0.0.0
  SMC Version (system):    2.43f6
Thanks.
txt
txt
log from after restart. .txt
56K
txt
txt
log copy.txt
1M
Post edited by AbnerK on
  • AbnerKAbnerK Posts: 718
    It's still happening after restarting both DS and my computer. How?
    2018-11-12 15:47:08.588 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00001 iterations after 66.620s.
    2018-11-12 15:47:08.602 Created RenderCacheBlock
    2018-11-12 15:47:08.607 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00552 iterations after 1032.745s.
    2018-11-12 15:48:00.047 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 15:48:45.467 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00611 iterations after 1129.606s.
    2018-11-12 15:48:45.468 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00006 iterations after 163.499s.
    2018-11-12 15:50:42.826 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00007 iterations after 280.858s.
    2018-11-12 15:50:42.844 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00679 iterations after 1246.983s.
    2018-11-12 15:51:18.253 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): recv failed errno=54
    2018-11-12 15:54:52.509 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 15:54:56.647 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00008 iterations after 534.679s.
    2018-11-12 15:54:56.653 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00751 iterations after 1500.791s.
    2018-11-12 15:57:25.010 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00009 iterations after 683.042s.
    2018-11-12 15:57:25.016 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00833 iterations after 1649.155s.
    2018-11-12 15:58:48.508 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 16:00:12.004 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00010 iterations after 850.036s.
    2018-11-12 16:00:12.015 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 01025 iterations after 1816.154s.
    2018-11-12 16:02:52.766 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 16:03:19.711 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00011 iterations after 1037.743s.
    2018-11-12 16:03:19.725 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 01134 iterations after 2003.864s.
    I'd have expected after 17 minutes for the tiny render of the eyes to b finished, whereas it's only 11 iterations and still looks terrible.
    I don't know what else to try other than shutting down the computer for a few minutes but you'd think that wouldn't make any difference compared to a restart.
    I shut my computer down for a few mintues and restared Daz. I was impatient so I changed two variables. I also send the scene to Lit Wirefram. The Spot Render to 2 minutes to get over 400 itterations which I find usually looks great.
    2018-11-12 16:19:03.441 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00346 iterations after 91.679s.
    2018-11-12 16:19:09.103 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00373 iterations after 97.341s.
    2018-11-12 16:19:13.555 Iray VERBOSE - module:category(IRAY:RENDER):   1.0   IRAY   rend progr: 74.97% of image converged
    2018-11-12 16:19:13.555 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00394 iterations after 101.793s.
    2018-11-12 16:19:18.395 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00417 iterations after 106.634s.
    2018-11-12 16:19:22.589 Iray VERBOSE - module:category(IRAY:RENDER):   1.0   IRAY   rend progr: 82.57% of image converged
    2018-11-12 16:19:22.589 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00437 iterations after 110.827s.
    2018-11-12 16:19:27.021 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00458 iterations after 115.259s.
    2018-11-12 16:19:30.293 Iray VERBOSE - module:category(IRAY:RENDER):   1.0   IRAY   rend progr: 85.49% of image converged
    2018-11-12 16:19:30.293 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00473 iterations after 118.531s.
    2018-11-12 16:19:31.699 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 16:19:32.348 Saved image: /Users/jim/Library/Application Support/DAZ 3D/Studio4/temp/d2.png
    2018-11-12 16:19:32.397 Loaded image d2.png
    2018-11-12 16:19:32.482 Finished Rendering
    Now I've got my eye's I'll test doing a spot render in Iray preview mode.
    Well, there's my second render going on. It has to be the Preview Render despite it not looking as if there's any render going on.  Same problem as before. If this happened everytime I'd have noticed by now. Why is it intermittent? At least I know it isn't worth putting the render into Preview Iray mode before I start rendering especially a Spot Render. See log beloe and attachement of it taking over 4 mintues now to still look bad.
    2018-11-12 16:24:11.575 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using built-in ray tracing (1.0.0).
    2018-11-12 16:24:11.575 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing scene graph.
    2018-11-12 16:24:11.575 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry.
    2018-11-12 16:24:14.534 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 3222k triangles, 1 instance yielding 3222k triangles) took 2.958483
    2018-11-12 16:24:14.534 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
    2018-11-12 16:24:14.718 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 85 textures, 0 lambdas (0 unique)
    2018-11-12 16:24:14.720 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
    2018-11-12 16:24:14.822 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
    2018-11-12 16:24:14.822 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
    2018-11-12 16:24:14.822 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
    2018-11-12 16:24:14.823 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
    2018-11-12 16:24:14.823 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
    2018-11-12 16:24:14.824 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1 layer frame buffer
    2018-11-12 16:24:14.824 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
    2018-11-12 16:24:14.824 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
    2018-11-12 16:24:14.829 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 4 cores for rendering
    2018-11-12 16:24:14.829 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
    2018-11-12 16:24:14.829 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-11-12 16:24:14.853 Iray VERBOSE - module:category(IRAY:RENDER):   1.3   IRAY   rend progr: CPU: Processing scene...
    2018-11-12 16:24:25.293 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : Initializing light hierarchy.
    2018-11-12 16:24:25.293 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : Light hierarchy initialization took 0.00s
    2018-11-12 16:24:25.402 Iray VERBOSE - module:category(IRAY:RENDER):   1.4   IRAY   rend stat : Native CPU code generated in 9.54e-07s
    2018-11-12 16:24:25.875 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : CPU: Scene processed in 11.046s
    2018-11-12 16:24:25.875 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : CPU: Allocated 541.711 KiB for frame buffer
    2018-11-12 16:24:28.258 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : Allocating 1 layer frame buffer
    2018-11-12 16:24:28.260 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00001 iterations after 13.431s.
    2018-11-12 16:24:28.272 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00040 iterations after 67.652s.
    2018-11-12 16:24:29.580 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00002 iterations after 14.751s.
    2018-11-12 16:24:31.060 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00003 iterations after 16.230s.
    2018-11-12 16:24:33.214 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00004 iterations after 18.384s.
    2018-11-12 16:24:35.923 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00005 iterations after 21.093s.
    2018-11-12 16:24:35.932 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00042 iterations after 75.312s.
    2018-11-12 16:24:36.827 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00006 iterations after 21.998s.
    2018-11-12 16:24:37.859 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00007 iterations after 23.030s.
    2018-11-12 16:24:38.830 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00008 iterations after 24.001s.
    2018-11-12 16:24:39.784 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00009 iterations after 24.955s.
    2018-11-12 16:24:41.950 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00011 iterations after 27.120s.
    2018-11-12 16:24:41.969 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00043 iterations after 81.349s.
    2018-11-12 16:24:44.391 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00045 iterations after 83.771s.
    2018-11-12 16:24:44.391 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00015 iterations after 29.562s.
    2018-11-12 16:24:55.198 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00019 iterations after 40.369s.
    2018-11-12 16:24:55.205 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00047 iterations after 94.585s.
    2018-11-12 16:25:03.525 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00021 iterations after 48.696s.
    2018-11-12 16:25:03.532 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00051 iterations after 102.912s.
    2018-11-12 16:25:14.621 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00022 iterations after 59.791s.
    2018-11-12 16:25:14.628 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00056 iterations after 114.008s.
    2018-11-12 16:25:25.221 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00023 iterations after 70.392s.
    2018-11-12 16:25:25.231 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00062 iterations after 124.611s.
    2018-11-12 16:25:35.479 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2018-11-12 16:25:37.812 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00024 iterations after 82.982s.
    2018-11-12 16:25:37.824 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00075 iterations after 137.204s.
    1530 x 1334 - 387K
    [Solved] of sorts:
    For Brevity anyonw with the same problem!
    What to do: Put your Preview Pain into anything but Iray before you start a render.
  • FishtalesFishtales Posts: 6,233
    I was about to say it looks like you have the main window or preview set to Iray and what you are seeing is the main/preview window rendering as you are doing the spot render so you were actually doing two renders at the same time smiley  But you worked that out for yourself yes
    edited November 2018
    Well, yes it seems obvious now after spending 3 hours working out. :D (irony intended)  but I've read in a few places that it's best to start a render with the preview pane also in Iray mode because it speeds things up. But clearly not. And it's also not obvious because as you can see in the attachment above the preview pane is not rendering anything.
    You have to give the preview or main window time to re-draw every time a change is made. If you give it time before trying a spot render you will only see one render in the log.
  • The render should stop any Iray previews fro processing, I thought - Might be worth a bug report to check it is behaving as intended https://www.daz3d.com/help/help-contact-us
    Thanks Richard, that's what I expected especially when you can't see it going on. It might explain a lot of my stubborn renders I've put down to other things.
    Thank
    Thanks again Richard, it just shows how much bad information is on this forum. Nobody is perfect, we are all still learning. This is the reply I got from Tech Support.
    The Iray Drawstyle is constantly rendering the scene, which is why the log file shows that two renders are happening simultaneously. Before you render, you may want to change the Drawstyle back to Texture Shaded.
     I have hardely ever not been in Iray when I started a render recently unless I'd happened to not think about it because of advice someone gave on the forum. You get to know who never to listen to though and who is right almsot all the time. :)
    Thank you as always for your tireless support.
