No Actor level in Parameters
Hey!
I made a wearable for genesis 8 in blender. it works fine. i wanted to add morphs to it and make them appear in the shaping tab. i read some threads from the forum and i found out that the morph type must be "modifier/shape" and the path must be somewhere in "actor". but there is no actor level in the parameters tab. not in the imported obj, not after transfer utility or converting it to a figure and also not after saving it as a prop asset.
does anyone know how i get the actor level to parameters tab?
thank you!
  • barbultbarbult Posts: 27,474
    In the Path: area, just type in the path you want your morph to be found in, for example, Actor/Adjustments. Then click Accept.
    Save your garment as a Figure/Prop Asset and save additional morphs you create for it as as Morph Asset.
  • Eureka. I spent hours yesterday trying to fix this and it's that easy?
    thank you very much, barbult!
