Group objects?
todoricurostodoricuros Posts: 0
How can i group objects?
  • cm152335cm152335 Posts: 421
    edited September 2013
    menu>create>group....
    edit: added
    note:
    select your object in the list before create group, (you can select all in the list)
    the Daz ask to you if you want to PARENT OBJECT in your group!
    Post edited by cm152335 on
  • Richard HaseltineRichard Haseltine Posts: 112,126
    Select them, then go to Create>New Group... and give it a name, if you mean combine several items into a set you can move around and adjust as a unit.
    If you want to create polygon groups in a model, you can use the Polygon Group Editor in the Tool menu, along with the Tool Settings pane.
  • todoricurostodoricuros Posts: 0
    Thank you guys!!!!
