how to make material zones on a figure?
davesodaveso Posts: 8,250
with geografting, you can add a suit whatever, but as a figure is..g3, g8, etc, the material zones dont make for a very convincing texture application.
How can those material zones be changed on the geograft?
Hopefully terminoloigy for that created layer is correct
  • RawArtRawArt Posts: 6,214
    a geograft is a piece of geometry added to a figure, so not sure that is what you mean.
    to make a new material zone you use the geometry editor tool and select the vertices you want as part of the new zone...go to the tool settings tab and right click on the material section and create a new zone from selection.
  • davesodaveso Posts: 8,250
    so overall its pretty simple, I guess. Thank you
    Yes.. I tried to do a geograft suit ... also even trying to do it directly on the figure, but around the neck and a few other places the zones didn;t allow what I was trying to do. just rying it. will take some time to figure it out
  • I've never used the Geometry Editor on a figure, but have used it quite extensively on older building sets and props. Love that handy tool and quite easy to use. :-D
