Refit garment to genesis after minor geometry change
Hello all,
I made a minor geometry change to pants in hexagon to create morphs. I used the transfer utility after converting the obj to triax. I can't get the pants to fit again so I can create the morphs in hexagon. Is there a tut for fitting the garment to genesis again and will auto-fit work afterwards? thanks
What is happening when you try? You can use the Transfer Utility with the old pants as the source and the new OBJ as the target.
Thanks Richard. I think I will take the originals convert to obj, make the geo change on it, then do the transfers. I think I know what I did wrong. Some how the legs are in the g3 zero pose width?
That worked!
