HOW DO I MAKE MY OWN CUSTOM CHARACTER
edited November 2018 in The Commons
Hi, I made a model using an existing character but i scuplted over it and now i want the character to be my own character like one whole morph for everything thing I did, how do I do that without the morphs showing the others I've used ?
Post edited by toussaint_18b9c935fc on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    First off, if you made your character over another and it includes any part of the other character it can only be for personal use and not shared or sold
    i am assuming you want everything in a single dial, correct? this might help
    If you simply want to combine morphs into one morph...you dial up all the morphs you want..
    Right click on the parameters tab and go into edit mode...
    Right click on "actor" and select "create new property.....fill out the pop-up with the name you want to give the dial, and where you want the dial to appear...then press "create"
    After creating this new property, right click on the new dial you made and click "ERC Freeze"..make sure all the elements you want are selected and press"accept".
    Then your new dial will dial in all those other dials.
    You can save this as any other new morph,...save as/morph assets
    Post edited by FSMCDesigns on
