G8F Skin textures
dash2128dash2128 Posts: 736
edited November 2018 in Art Studio
I need to remove the mole (skin spot) on the right side of the face (near the nose- see screenshot) of my g8f females, which seems to remain, even after applying a character to the figure.
Do I need to apply a skin texture?
More precisely, the basic g8F figure works fine for this character, which is...not quite human, so the shiny skin is okay.  But the mole (or facial spot)  needs to go, the character would not have one.  Any suggestions?
643 x 620 - 49K
  • FSMCDesignsFSMCDesigns Posts: 12,858
    You'll have to edit the texture in photoshop or GIMP. Go to the surfaces tab, then select the face and then the diffuse slot and browse to the texture on your system. select it and open with your image editing software, edit, save a copy and then load that copy up instead of the original. Or you could just apply a different skin set.
  • dash2128dash2128 Posts: 736
    Thank you for replying!
    Would Skin Builder 8 for Genesis 8 do the trick?
    I just noticed it.
    1099 x 653 - 130K
  • caravellecaravelle Posts: 2,791
    With Skin Builder you create a new skin texture; it doesn't alter existing ones. Try FSMC's method; it's easy!
    Post edited by caravelle on
    FSMC's method?
    What is that?
  • Victor_BVictor_B Posts: 392
    The method which FSMCDesigns described in previouse post. caravelle just cut off his nickname. That's funny.
  • Moved to Art Studio as it's a "how to" question, not a Product Suggestion.
