Issues with Models and items within Daz3d
So when I open the program and notice the sceen navigation is kind of white washed with nothing in it... Nothing major I can work around this.... then models and assets load with notexture or shading... It will render the texture and shading but itwont display. I'm attachinga SS of what is going on. Daz is the only thing going with this issue. I've uninstalled, installed, removed assets,checked drivers, and rebooted twice.... HELP!!
1920 x 1080 - 428K
That looks like an OpenGL issue, make sure - if you have two GPUs, as for example an Intel CPU-GPU and a separate nVidia or AMD GPU, that DS is set to use the stand-alone GPU. Fo rnVidia that would be in the nVidia Control panel, for AMD I assume it would be the Catalyst Control panel.
