Spot Rendering on Big Renders?
DrowElfMorwenDrowElfMorwen Posts: 539
If I am rendering something bigger than the active viewport, I need to know how to spot render one section so I don't have to sit through another half-hour or more long render. I still haven't discovered how to do this, if it's possible.
I am using DAZ Studio 4.6.
  • KeryaKerya Posts: 10,943
    Spot render
    Windows / Panes / Tool Settings
    dropdown menu for Active Tool / select Spot Render
    Two radio buttons: Select New Window
    Use your mouse to draw a rectangle over the the section you want to render
    Save spot render and insert in Gimp/photoshop over the place you want to change
  • DrowElfMorwenDrowElfMorwen Posts: 539
    THANK YOU!! ^o^
  • Richard HaseltineRichard Haseltine Posts: 111,647
    With the Spot Render tool active go to the Tool Settings pane and change the setting from Viewport to new Window.
