Pesky Octane
VyusurVyusur Posts: 2,235
Does anyone know how to remove Octane from Daz Studio? I installed the demo version and now I can't get rid of it.
  • Not liking Octane? I have no idea how to get rid of it if the conventional uninstall options arent working.
  • nicsttnicstt Posts: 11,715
    it uninstalls fine. Just tried the usually way.
  • I have the OrDs2 version and I just add .bak to the dll to disable it as I often need to running batch scripts like the clothing converters
  • VyusurVyusur Posts: 2,235
    I tried the usual way several times before I wrote this post, it didn't help.
  • Beat578Beat578 Posts: 191
    There is a Folder "OctaneRender" inside your Plugins folder of the DAZ installation. Deleting that together with your User Settins (can be found in C:\Users\YourName\OctaneRender) should do the trick... I am not sure if there are other places, but only for the plugin that should be it. If you use Octane Standalone I would ask in the octane forum, if you should delete the files in your personal folder, as they could be for Standalone as well.. Hope that helps.
  • ArtiniArtini Posts: 10,957
    Thanks for the warning about such issues with Octane.
    I will think twice, before I will decide to install it to Daz Studio plugins.
    At last, after several tries, I uninstalled it with standard Windows utility.
    Simple and realy the best way You can do.
